Re: Milky hy-trans fluid on 1256
Posted by JayWalt on March 28, 2007 at 09:47:46 from (69.214.159.61):
In Reply to: Milky hy-trans fluid on 1256 posted by Brian in AR on March 28, 2007 at 06:39:16:
Brian, heres the thing, there is no way to get all of the fluid out of the tranmission, pump, hoses and so on. The only way to get it clear is to keep draining and readding fluid, then running it a bit, then repeat. Now that can become quit expensive. I believe the 1256 has ALOt of hytran in it, around 10 gallons give or take a few gallons. You can heat up the oil to drive the water out. Be careful to not burn the oil, keep it above 220, but below 250. That is ALOT of fluid to boil. Took me a good day to do 3 gallons, but I only had one pot. If you do decide to do it, do not put the pot on the stove or burner and crank it on high to get it up to 220, u will burn the oil on the bottom. Put it on about 3 or 4 and watch the temp with a candy thermometer. While the fluid is hot run it through a fine mesh or filter to remove contaminates, dont use a coffe filter, as its way too fine. Other then that, there really is no way to get the water out. You might be able to work the tractor and leave the fill cap off, but I'd be scared of getting crap in there. Even doing that will take forever to drive all of the moisture out. Unfortunately its the nature of the beast, unless u want to diassemble and drain every part of the system, its just not feasible to change it once and expect the old fluid to not mix with the new fluid.
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
