Re: Super H slips out of 5th gear
Posted by Janicholson on March 31, 2007 at 06:37:35 from (66.216.226.55):
In Reply to: Super H slips out of 5th gear posted by sonny IH on March 30, 2007 at 19:06:41:
This topic is somewhat complex. The archives here ((search for)) ABOVE, Will have fifty posts pictures and comments. The primary reason is abusive shifting into fifth by operators that rake it past the grinding teeth (actually splines on the input shaft, and fourth fifth slider) with force. The solution may be good NOS gears, Pricy, or good used gears. The Belly pump, and top cover need to be removed but no split is needed. Shifter forks and rails as well as the tip of the shifter should be inspected as well to assure a good repair. Bending shift forks is (usually) a make shift (interesting word use) way of getting a bit more use out of it, but not too correct. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
