Re: Cant get H to run
Posted by riverbend on March 31, 2007 at 07:13:05 from (208.160.34.246):
In Reply to: Re: Cant get H to run posted by eshoreboy on March 30, 2007 at 20:14:32:
Nope.
You might have to take the valve cover off and crank the motor to be sure that you are at TDC on #1 cylinder's firing stroke. You will see the exhaust open and close, the intake open and close, and both rockers will be a little loose. The timing mark will line up with the pointer, and the mag rotor should point to the #1 plug wire.
The other case is that you are choking it too much. On your first try to start it, leave the ignition off, pull the choke rod all the way out, and give it two cranks. Push the choke all the way in, open the throttle 6 or 7 clicks, turn the ignition on, and crank it over.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
