Voo Doo 450
Posted by georgeky on April 03, 2007 at 06:01:45 from (152.163.100.197):
I bought a 450 diesel from an estate about 3 months ago that had sit for 14 years. The boy's that inherited the tractor tried for 3 days to start it with no luck. I bought the old tractor fairly cheap brought it home and started cleaning fuel tanks and fuel system along with the carb. I added fresh gas and with a little pull she came right to life. I then proceeded by the book and bled the fuel system and low and behold it switched and ran fine on diesel also. The trouble was the hydraulic pump never even grunted. I bought another one to put on it and guess what. I started the tractor 3 or 4 days ago and heard a little noise from the pump. I reached up and turned the wheel and the factory power steering worked perfectly. Now the fast hitch, steering, outlets and all work fine. Do you guys think maybe it was a stuck valve or something? I am just glad everything is working. I have put the 4 row fast hitch planter on this and am going to run it, seems like it gets better all the time. Also there was no hydraulic oil at all in the tractor when I got it maybe everything was all dried up.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
