Re: Farmall A engine
Posted by Janicholson on April 05, 2007 at 19:54:09 from (66.173.50.49):
In Reply to: Farmall A engine posted by Tyler Cohrs on April 05, 2007 at 18:56:05:
Smoke at Idle may be valve guides. If you idle down a hill in high gear, does it smoke even more? If so it could use guides. I like Perfect Circle valve seals. They regulate stem oil consumption and do not require pulling the head to install, and modest in cost and time.
If the cap is held on with the groves on the outside of the neck it is a Pressure system (4-6# cap). If the cap is fastened into grooves on the inside of the neck it is atmospheric. (that cap looks a lot like the gas cap. A water pump can be added with some mods to the drive belts, however the thermosiphon system works very well if the block and radiator are nice and clean. If they are filled with rusty deposits, the pump will only mask the issue. Flush and clean the system first to get a handle on the condition of the deposits.
Good luck, JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
