Re: IH 560 brakes, IH disk brake question?
Posted by Bob M on April 11, 2007 at 13:09:20 from (151.190.254.108):
In Reply to: IH 560 brakes, IH disk brake question? posted by Rick in Central MD on April 11, 2007 at 09:18:46:
I can't speak for 560 disk brakes. But I've operated/worked on Super H/M disks (which I believe are identical to the 560) for 40+ years.
My experience is IHC disk brakes - when properly maintained and adjusted - work just well a dry disks by the other tractor builders. (And they work better/last longer than most external band and internal drum brakes of the same era...)
A few things that help disks perform well and live long:
- Don't let ANY oil get into them. Bull pinion shaft seals must tight!
- Don't let water get into them either. Rust raises hell with friction surfaces.
- Keep the bull pinion splines clean and LIGHTLY lubricated.
- Replace the friction disks if they become worn, oil-soaked or glazed. And if the cast iron braking surfaces are glazed, sand them clean before installing new disks.
- Keep the actuating (center) disk assembly clean. Replace the balls if they become worn or deformed.
- Keep the pedal linkages properly adjusted. DO NOT let them drag so the brakes overheat!!
- If a pedal return spring breaks replace it IMMEDIATELY. Or at least put a bungee on the pedal to hold it in the released position until you can get a new spring.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
