Farmall Tractors Discussion Board
Re: Re: CUB hard to start
Posted by George Koehler on May 02, 1999 at 15:46:26:
In Reply to: Re: CUB hard to start posted by RK Smith on April 18, 1999 at 05:13:09:
The 6Volt Cub is a positive ground system, magneto ignition. It is important that you connect it as a positive ground since that affects performance and life of generator and starter.
You may have already damaged the starter if you were operating as negative ground. That is a simple check at your local generator/starter/alternator repair shop. Also if you connected up as negative ground you may have affected the polarity of the generator. Get that checked as well. The battery/generator system only cranks the engine and runs the lights. The ignition is an entirely separate magneto system which is not connected to the battery.
I would say that trying to convert to 12 volt system would be unnecessary since you can still get the right 6 volt battery.
Post a Followup
: Re: Re: Re: CUB hard to start
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
