Farmall Tractors Discussion Board
Re: What the H is going on here????????
Posted by RKS on May 02, 1999 at 19:08:07:
In Reply to: What the H is going on here???????? posted by Weekend Farmer on May 02, 1999 at 17:23:54:
rust probably from moisture and inactivity before you owned the tractor, and probably flaking from the inside of the valve cover. the same type rusty flaking may have deposited inside the water jackets and also inside the radiator, so that the reduced flow may be allowing it to run hot. you sure the guage is working correctly? shouldn't get over about 220 generally. If the running hot problem persists or gets worse, you will have to find out why. first look would be radiator, which you may need to have boiled out with solvent at a radiator shop. I would take a look at the timing, because if it is too far out of time, particularly if the detonation is way behind recommendations, the engine will run hot. RKS
Post a Followup
: Re: Re: What the H is going on here????????
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
