Re: Question on governor spring.
Posted by BF8690 on April 20, 2007 at 08:29:44 from (138.163.0.38):
In Reply to: Question on governor spring. posted by unioncreek on April 20, 2007 at 06:54:10:
The spring should be loose at idle. Atleast mine is. The service manual gives good instruction on how to adjust the governor as well as the throttle linkage from the governor to the carb. Inside the governor are two stop bolts. One of them sets the max RPM at military, or full throttle. I don't remember exactly what the one does. Take off the side plate from the governor. Take off the top breather tube from the governor, then drop the bowl off of the carb. Open the throttle as far as it will go, you may need someone to hold it back for you. Make sure that the butterfly is open all of the way. If it is not, then adjust the governor throttle lnkage at the top of the breather tube access for the proper throttle setting. It has been my experience that if this is not correct at full throttle it will effect idle also. That will ensure that the max RPM setting and idle setting for the carb is correct. You may want to check your idle speed and fuel main needle. It could be as simple as it is to rich, to lean or not enough RPM at idle. You can also modify your fuel meter tube inside the carb, since you have your bowl off it will be easy to do. Take out the main needle. Then take out the fuel metering tube. Then insert drill bits, into the main jet, one at a time starting with the smallest one. When you get to the drill bit that won't fit drill out the main jet. Then using the same drill bit drill out the the two lower holes in the fuel metering tube. This will give you much more adjustability at the main jet needle. IH carbs were notoriously lean for fuel economy. I did all of this to my 1944 M and it runs way better than it did prior to. Hope this helps.
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
