Re: Curious about a Farmall M's hydraulics and stu
Posted by Nat 2 on April 25, 2007 at 06:05:25 from (64.80.108.53):
In Reply to: Re: Curious about a Farmall M's hydraulics and stu posted by Patrick Martin on April 25, 2007 at 00:47:35:
Patrick, You seem pretty excited. Calm down and let's take things one at a time. Once you get the tractors home you'll have all the time in the world to assess the situation, figure out how things work, and figure out what you're going to do. M's come with a "belly pump." It is driven off the transmission, so when the clutch is pushed the pump stops pumping. It's capacity is 6 quarts as I recall, not much. The belly pump is a one-way system, pressure up, gravity down. In its day, light years ahead of lifting by hand or just dragging the implement home from the field. When you see two hoses, that means someone added a two-way valve to the tractor. The two-way valve redirects the fluid to give pressure in both directions. These are very easy to add, but will cost you a couple hundred dollars for the valve and hoses. The belly pump has three ports, two on the left, one on the right. They may be plugged or they may have quick connects. It's very easy to add quick connects yourself, and I recommend it. All three ports are controlled by the rod on the right side. Pull the rod, and two ports lift simultaneously, the front on the left and the right port. Hold the rod and when the cylinders are fully raised, the rear left port starts to lift. It's a delayed lift for the rear "tire track scrubbers" on a front-mount cultivator. You almost never use the rear left port. Live hydraulics involve an engine-driven pump that mounts in front of the distributor. Since the engine is turning the pump directly, you always have hydraulics even when the clutch is pushed. Unless you are very lucky, neither of your Ms has live hydraulics. It wasn't available when the tractors were new, and only a few were added later on. Adding live hydraulics is EXPENSIVE, costing at least $800 for the pump, hoses, valve, and reservoir. I would NEVER buy a used pump, only a new IH pump because these pumps are not rebuildable. An old pump is probably worn out. It's not worth the risk. Hopefully this makes things clearer. Good luck!
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
