Re: H Voltage regulator
Posted by John T on May 03, 2007 at 19:27:51 from (66.244.83.147):
In Reply to: H Voltage regulator posted by BF8690 on May 03, 2007 at 15:37:48:
BF, Im not sure I follow whats happening?? 2 amps of discharge not running??????? You mean when you shut the tractor off the ammeter registers - 2 amps. If the VR"s Cutout Relay was sticking closed I would suspect that to be wayyyyyyyyy higher (like maybe - 20 amps) so I question the ammeters accuracy for now. If you were to remove a batery cable would it still show - 2 amps or go to 0 ???????? If it goes to 0 there must be a minor short somewhere explaining the lower charge of only 3 amps and the 2 amp discharge. You ask how to tell if the VR is working.... When running dead ground the gennys field post n see how many amps she charges then !!!!!! If that makes it charge at more like 10 amps right after a start up, I suspect a VR problem or maybe the VR isnt well grounded TRY A GOOD GROUND JUMPER WIRE TO THE VR"S CASE N SEE WHAT HAPPENS I agree with Bob n Hal, 6.8 volts and 3 amps is too low right after a start up. Make sure the belt is good n tight and try a better ground on the VR (and genny also) and then try to dead ground the gennys field post n see how much she charges then. Also see if the ammetr stays at - 2 amps with no battery connection. John T
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
