Re: 706 looses power on long pulls
Posted by Owen Aaland on May 11, 2007 at 09:25:12 from (65.161.86.75):
In Reply to: 706 looses power on long pulls posted by cjd12000 on May 11, 2007 at 03:55:48:
I would check the spark plugs to make sure they are not too hot a heat range for what you are using the tractor. If it was not used under much load before it may well have hotter plugs to keep them from fouling. As the plugs heat up under load a hotter plug will not transfer the heat fast enough and the overheated plug can cause preignition, even to the point where the fuel mixture is ignited as it is being drawn into the cylinders. This will cause backfiring into the carburetor. A Champion D21 can be used for engines under light load. Champion D18Y has become the new standard. Champion D15Y was the originally suggested plug. If you are loading the tractor enough you can get by using the D15Y plugs. Better to be too cold rather than too hot. If you start with a colder plug you can move to the next hotter if you have fouling problems. Be sure to go back to colder plugs for heavier use. My Super C running a Woods 6 foot mower runs just fine with D15Y because it is usually under enough load to keep the plugs clean. On the other hand, my I2444 has D21s in it becuase it is used almost exclusively for loader work and D18Ys would sometimes foul out. Both engines have had recent overhauls and neither uses any oil but different loading requires different heat ranges on the spark plugs. Preignition can occur just a few degrees before normal spark ignition and you may not be aware of it happening but it will cause the pistons to run much hotter and will lead to piston failure. Higher octane fuels can mask this problem by being less prone to preignition but it is better to run colder plugs to eliminate the source of the problems.
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
