Re: axle differences
Posted by CNKS on May 11, 2007 at 17:55:06 from (204.249.178.32):
In Reply to: axle differences posted by wegman in Mn on May 11, 2007 at 14:43:21:
Case-IH won't have the parts to convert it to a Hi-Utility. The front spindles are longer. You will have to use the rear end from the TA back from a 300 row crop, or change some or all the gears in the transmission/differential. The 38 inch rears and axles are the same as the row crop. If you don't change the gearing, the ground speeds will be faster. If it has fast hitch, some of those parts are different too. Many other parts are different, also. I don't think what you want to do is practical, but that is up to you. I have a 460 Hi Utility, and have had it completely disassembled. The parts book indicates numerous differences from the regular utility, I imagine the 300 is similar. By the way, IH did not make a 300 Hi Utility, they did make a 350 Hi Utility.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
