Farmall Tractors Discussion Board
Re: H governor spring
Posted by mj delaney on May 07, 1999 at 07:27:31:
In Reply to: H governor spring posted by John on May 06, 1999 at 07:53:21:
I sympathize with you. I have a spare "H" governor, where the spring was shifted to a replacement like you describe. Someone had cut off and placed a sawed off bolt inside it, I assume to dampen the spring action but I'm not sure. My working "H" tractor still has the original.
I note that Walt's Tractor part's website lists a high performance governor. I e-mailed them to ask what they mean't by high performance. I did not hear back from them. I also note that the blue ribbon service manual talks about a tighter regulation (5%)spring for the U4 stationary model of the H so maybe that's the context? Maybe you could check with them on a spring. I know that you don't want any more wear than necessary in the linkage as it no doubt affects governor performance.
I noticed that in this spare governor assembly I have that there was considerable wear in the arm attached to the speed change lever and that is what this clevis assembly you describe probably prevents. I would probably try to find a used one if I couldn't get new. I guess it depends how much you intend to use the tractor.
I've been around the block on this governor issue lately, trying to get a few more rpm's out of my tractor for pto work. I have learned that you can jack the adjustments around all you like. For my tractor it seems that I had to stick as close to original settings as I could or the linkage would bind. I did check the pto speed with a shaft tach and I'm getting enough speed with no load. So I am now assuming that my rpm drop off while baling and hauling a wagon is probably related to the fact that depending on topography etc, I've got a little too much load for the tractor. Good luck with this one. I'd be most pleased to hear how you make out.
Post a Followup
: Re: Re: H governor spring
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
