Re: Got my MD home today!!!
Posted by Haas on May 21, 2007 at 06:57:58 from (12.65.54.171):
In Reply to: Got my MD home today!!! posted by jonnnny2006 on May 20, 2007 at 23:29:54:
Be aware that the magneto rotates counterclockwise(facing the rotor), opposite to what you normally expect. So..you need to connect the plug wires accordingly. Have you checked the points to see that they are properly set?? If you got a shock, I would think the mag only needs some tuning up. Also, the point cam in the mags has only two lobes, so there is gearing between the cam and the rotor. You must have the timing correct so that the rotor points to No. 1 plug wire contact when the No. 1 cylinder is TDC of the compression stroke. Be aware that on the MD, changing to gas side does four things. 1) changes butterflys in the manifold to direct air through the carb. In diesel mode, air does not flow through the carb. 2)Turns the ignition on. That is ungrounds the mag. In diesel mode the mag is grounded to stop the spark. The switch is in a chamber at the front of the manifold. 3)Releases the carb float to allow gas to flow. On the diesel side the float is locked up to stop gas flow. 4)Opens the compression release valves to the spark plug chambers to reduce compression. In diesel mode, the valves are closed. Also, check the plugs to make sure you have the correct long reach Champion D89 plugs. These have a long electrode to facilitate combustion in the chamber that is restricted. They will cost around $8 each. When you have everything right, the MD should start in gas mode with only a turn or two. Mine requires full choke to start and then fiddle with the choke as it warms up. There is no throttle control except by removing the carburator and adjusting a plate inside. Keep us posted.
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
