966 Charging System.
Posted by GordoSD on May 25, 2007 at 17:41:58 from (66.115.200.140):
My 966 has the large dual 6 volt batteries. Been having low crank or no crank problems. Removed alternator and took it to elec shop. Tested out a zero charge. Owner rebuilt it while his wife cut my hair. Out of there in 35 minutes with 'new' alt. Installed and nice charge on alt gage. Then after a days planting. No crank, low batteries. Batterie fairly new and tested OK.
Charged the batteries up. Tested with voltmeter at 6.65v. Installed and Fired the old girl up.
Put meter on each battery and it still read 6.6 volts.
My question is where does the output from the alternator enter the system? and why does the battery that is second in line read 6 volts insted of 12? Does that alternator put out 12 volts or 6?
Where do I check for alternator output?
And yes, I am leaving the key switch on.
Gordo
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
