Farmall Tractors Discussion Board
Re: H Starter and Alternator
Posted by RKS on May 09, 1999 at 09:13:32:
In Reply to: H Starter and Alternator posted by TomH on May 09, 1999 at 06:06:07:
also, unless your alternator just happens to be a rare "pos ground system," you must make sure your H is converted to "neg ground." The alternator won't work if not. Also, you have to know if it is an internally regulated model or requires a voltage regulator. You must be positive, or you will fry the battery (maybe a new one, huh?). If it has a clip with "F" for field marked on it, you will probably need a voltage regulator (recommend AutoZone 129965 VR706). There are other issues which you must be aware of in the wiring of the system. Good luck. RKS
Post a Followup
: Re: Re: H Starter and Alternator
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
