Farmall Tractors Discussion Board
404 ?s
Posted by Kip on May 09, 1999 at 12:50:50:
I got my Ex-cottonpicken Farmall 404 running it runs good I put rings, bearings in it and had a valve job done the tractor was a one owner it had a 314 cotton picker on it since it was new which I have removed the motor showed very few signs of wear he only picked about 200 acres a year with it. If it had'nt set up and stuck it would've had several years left on the motor Question #1 you have to have the choke about half way out for it to run what could this be.Question #2 I don't have any of the 3pt hitch arms all I have is the splined ends of the rockshaft coming out of the housing A local salvage yard has a Farmall 504 with all of the hitch intact I know the rockshaft arms will work I got the numbers off them but I don't know about the leveling asemblys or lift arms are they the same or not do any of you know THANKS
Post a Followup
: Re: 404 ?s
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
