Re: What engine in 706?
Posted by the tractor vet on May 29, 2007 at 21:13:56 from (76.212.225.19):
In Reply to: Re: What engine in 706? posted by dave560 on May 29, 2007 at 20:27:49:
Well ya can just buy it from Case I H or ask your fuel supplier for Low ash oil . And any of the stuff made after the M's used detergant oil to help clean the engine . So i don 't know what model tractor you have but most people have switched many years a go . Now if you have not and are going to then it is wise to pull the pan and clean it and go on a 50 hour change for awhile to get the engine cleaned out . That old Non Det. oil can cause rings to stick and have lot of sludge build up . Guys talk about mulit grade well that is fine in the newer stuff as the engine clearances are tighter and they will hold better lube pressures the older stuff were not that tight . Multi grades did not realy come on till the mid 70 's in Hd operation . When i bought my 4370 I H with a cummins the book called for stright weight 30 w seires 3 oil . I was one of the unlucky ones that got some of the bad liners from the factory and my engine was toaste at 65000 miles Cummins put in a new engine and this one was to be run on 15-40 series 3 so Cummins changed in mid 77 But the 86 seires tractors were still running the stright weight seires 3 oils .So i feel like this the boys that designed the engines know far more then me .
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
