Farmall Tractors Discussion Board
Electronic Ignition on 806
Posted by Ken T. on May 09, 1999 at 16:33:38:
Today I installed the Genesee Products electronic ignition on my 806. It was easy to install and the tractor runs fine (about the same as with a new set of points). There were two things that I did not like, however. 1. The wires supplied with the kit were too short. It came with 16" of wire, and I had to splice in another 16". I had to solder the splice just to make sure it would not be a problem at some future time. The kit cost $85.95 which I gladly paid, but for that price, you should get plenty of wire so you do not have to make a splice. 2. The magnetic pickup takes up a little vertical space on the distributor shaft. Because of this, the dust cap does not fit. This is no problem for me because I just use this tractor in the woods, but if someone was to use their tractor in the field, dust entering the distributor may be a problem. Anyway, now I do not have to install points again, so I am satisfied that an improvement has been made. If you are interested in purchasing this system, go the the YT home page and click on parts & supplies, then look for Genesee Products. Note: I have no affiliation with them whatsoever.
Post a Followup
: Re: Electronic Ignition on 806
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
