Farmall Tractors Discussion Board |
Re: Coolant getting in the base on super c ?
Posted by Phil Auten on May 10, 1999 at 06:17:59:
In Reply to: Coolant getting in the base on super c ? posted by MT on May 09, 1999 at 12:37:47:
MT, Another guy I know of had a similar problem with an Oliver. He fixed it with new head bolts. The old ones were stretched too much, not allowing proper torque to hold the head gasket properly. I would try the gasket first and then replace the studs/nuts and then check the seals at the bottom of the sleeves. The PO said he had the head off, so that is the first thing to suspect. One other thing to check is to take the head to a machine shop and have it Magnafluxed for cracks and checked for flatness. If the head's cracked or warped, it will never seal. Good luck, Phil
Post a Followup
