Re: F-20 Heisler OD removal
Posted by cole in mo. on June 02, 2007 at 19:27:47 from (65.255.149.240):
In Reply to: F-20 Heisler OD removal posted by Scott in SC on June 02, 2007 at 14:14:08:
If this is the heisler cast iron trans that gives you 8 speeds, there are the two you can see, then after you remove the front cover there are 6 more inside. You gotta take the shifter shaft and gears out before you can get to some of the bolts. Be very carfull when you take it apart, and watch where things go, don't let the syncronizer ring come off the hub, there are 6 springs, and 6 ball bearings under it, and a real bear to put back togather. There are no bolts to be removed from inside the tractor trans. And if its like mine you gotta unbolt and shove the engine and radiator forward enough to get clearnce.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
