Re: IHC W450-D Question for the pros **(URGENT)**
Posted by steelfronts on June 05, 2007 at 19:19:35 from (71.82.92.144):
In Reply to: Re: IHC W450-D Question for the pros **(URGENT)** posted by Brian Jensen on June 05, 2007 at 08:43:40:
Did you get the email I sent the other day? Are you sure the valves in the manifold are working. If the dist is loose crank the engine till the pointer on the front cover is lined up with the tdc mark on the bottom pulley. Then rotate dist till you get spark from number one wire. At least this should put the spark close enough to get a fire. When you try to stat it does it just roll over and over and never putt or backfire or anything?Are you sure you have the wires back on in the right order? We will get this running
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
