Re: Super A with sloppy steering
Posted by Hugh MacKay on June 10, 2007 at 03:12:02 from (216.208.58.99):
In Reply to: Super A with sloppy steering posted by Chris Gatti on June 09, 2007 at 20:16:31:
Chris: Very seldom are the worm and gear worn. If there is no end to end movement in the steering wheel shaft those bearings are fine. 98% of the time the problem is on the vertical shaft, both inside and outside the box. Inside the box the gear is keyed to shaft using a woodruff key. On the outside the steering control arm can be loose on the shaft, it may be as simple as tightening the nut at bottom. Two systems were used over the years where steering control arm mounts to tapered shaft. A and early SA used a square tapered shaft, and those can be tightened using thin shim stock. The later models have a round tapered shaft using a woodruff key. I have seen them more than full turn on wheel and whole problem was right on that vertical shaft. Usually those keyways need repair, or grind oversize keys to make them fit tight. Close to 20 years ago, I did my SA, ground oversize woodruff keys. For the gear I welded key in place and ground it enough so gear had to be pressed on with hydraulic press. For the steering control arm I was able to get a tight fit, grinding an oversize key. It is still tight as new in steering. When your finished, forget about gear oil in the gear box. Place a grease zerk in drain port, and pump the box full until grease comes out the fill port, probably 3-4 tubes of grease, then every time you grease tractor, give the steering box abot 6-8 pumps. Your steering will stay tight, and you'll never have an oil soaked front end again. Best to use moly grease in that gear box, doesn't get stiff in cold weather.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
