Re: F-12 Power Lift and Peg for Seat Brackets
Posted by David Allgire on June 14, 2007 at 06:48:36 from (24.217.111.191):
In Reply to: F-12 Power Lift and Peg for Seat Brackets posted by Dan Oehmke on June 11, 2007 at 20:17:59:
Yeah it can be a pain. Pull both cotter pins. I used a long bar that will fit through the hole in the support to start the pin moving toward the left. Then I went to the left side and did the same. There is no hole on the left side so you have to strike the pin at an angle. I also applied some Kroil to loosen things up. By moving the pin back and forth, you break the rust bond and can get a pair of vise grips on the right end and finally twist it out. I didn't have to use any heat. Just got to be persistant! Hope this helps.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
