Farmall Tractors Discussion Board
ATTENTION: all rebuilders, new buyers, troubleshooters
Posted by RKS on May 13, 1999 at 04:38:10:
If you are buying, rebuilding, or troubleshooting an old tractor, just remember - that old thing may have the original ignition wiring from the factory - maybe 50 or 60 years ago. Probably half or more of the ignition problems on this board, problems which lead to who knows how much expense, worry, and delay, not to mention "parts" which aren't needed, could be eliminated by one simple action. Pick up some wire and ring connectors anywhere you want to and carefully remake all the primary ignition wire harness connectors, links, leads, etc. Also, for convenience, and for "safety," consider going ahead and spending the money for new battery cables and spark plug harness wires. This might be $30-40 total, plus your labor. However, it will be well worth it in time and grief saved later. A 50 year old wire may look like new, but it has been through millions of cycles of expansion and contraction, and it has been knocked, pulled, pinched, heated - you name the different types of abuse, including corrosion and rust. Worse, they don't have to completely fail to ruin your operation. Just a partial short will rob the system of the correct voltage tolerances, and old weak unstable wires can "open" at any time from sensitivity to temperature. Do yourself a favor - change them. RKS
Post a Followup
: Re: ATTENTION: all rebuilders, new buyers, troubleshooters
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
