Use Grease If Necessary
Posted by A. Bohemian on June 16, 2007 at 12:11:19 from (207.170.88.83):
In Reply to: Re: Farmall Super C: Filling the front steering reservior posted by georgeky on June 16, 2007 at 09:32:18:
If the seals are bad, you will likely dribble out the oil in a few days or even hours. So, you can try adding oil. But if it all leaks out in 48 hours or so, consider using grease like Georgky says. By the way, you do NOT fill through vent plug! Simply remove the vent plug and make sure it is clean and not clogged and replace it. In all probability it IS clogged; radical temperature change in combination with a plugged vent causes most seal failure. On the left side of the steering gear housing (left as you look at the FRONT of the housing) is a second, somewhat larger plug. This is the fill AND level plug. In other words, fill to the top of THIS plug hole, not the vent plug hole. There is a third, smaller plug, horizontally as opposed to vertically oriented, beneath the filler plug. This, as you can no doubt surmize, is the drain plug.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
