Farmall Tractors Discussion Board
Re: My M won't move!
Posted by justin on May 13, 1999 at 16:06:50:
In Reply to: My M won't move! posted by Bill on May 13, 1999 at 12:25:57:
okay, the way this is starting to sound, is that the pilot bearing that is between the transmission main shaft and the transmission input shaft, has wen't out, and locked the two shafts together.. this would explain the road gear in neutral, because this problem is more or less a direct lockup between the input and main shaft, which the 5th gear does.. Now, as to damage, the pilot bearing is definately shot, the mainshaft (where the bearing sits may be scarred) and may need to be replaced, and more than likely the input shaft is ruined.. This problem is common on Ms, and the parts are around.. if what I described above is the case, email me, because I have some of the parts which you will need to repair the tractor..
Post a Followup
: Re: Re: My M won't move!
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
