Farmall Tractors Discussion Board
Re: Re: 6V. to 12V. Question
Posted by Mike McKay on May 18, 1999 at 21:14:56:
In Reply to: Re: 6V. to 12V. Question posted by The Red on May 18, 1999 at 10:54:35:
You do not put the resistor beyween the coil and the distributer. It goes in the 12 volt power source normally from the switch to the coil. We went over all of this the other day on here. A 12 volt coil is fine as long as you have one that does not have an internal resistor. If the tractor is running OK leave it alone. Check the coil to make sure it doesn`t get to hot. Place your hand on it. If you can hold it there is should be OK. Don`t fix something that doesn`t need fixing. Good Luck!
Post a Followup
: Re: Re: Re: 6V. to 12V. Question
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
