Posted by Janicholson on March 21, 2009 at 17:22:12 from (66.173.50.9):
In Reply to: Hard to start BN posted by PIRATEFAN on March 21, 2009 at 17:05:54:
Possible intake manifold leak, or internal crack leaking making it lean. If it does not smoke and has good compression, that is a likely problem. When running, use a propane torch with the tip removed to allow raw propane to come out. Run the tractor outdoors, and see if moving the propane around the manifold makes a difference in the way it runs. JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
