Farmall Tractors Discussion Board
Re: farmall 450 gas won't start
Posted by RKS on May 20, 1999 at 03:03:31 from (152.201.154.10):
In Reply to: farmall 450 gas won't start posted by mark s. on May 19, 1999 at 19:04:35:
Pete is right - if you confirmed the match of the timing mark to the pointer and the dist node position of the rotor "at a different time" from the time you connected the plug wires to the distributor. If you anticipated that each time the timing mark lines up, that you are firing number 1, then you must remember that the engine is a four-stroke, - - power and exhaust are one revolution, then intake and compression are another. So, every "second" time the timing mark appears at the marker, number one fires. You have to be sure that the marker is lined up "and that number one is at the top of the compression stroke." Only then will the rotor point to number one on the distributor node. I think Pete is right, and if you made this common mistake, she'll fire right up. If you are positive that you have already done this correctly, then I would be suspicious of the fuel lines or the carb, since you know you are getting fire. Just because there is no water in the glass sediment bowl doesn't mean fuel is flowing into the main jet venturi or the idle jet. Come back and let us know what you find. RKS
Post a Followup
: Re: Re: farmall 450 gas won't start
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
