Farmall Tractors Discussion Board
Re: A's Brake Pedal Lube?
Posted by Daniel on May 27, 1999 at 07:25:41 from (206.74.50.21):
In Reply to: A's Brake Pedal Lube? posted by Lynn Hait on May 26, 1999 at 06:08:10:
My super A has grease fittings on the cast supports that hold the break pedal rod. They are on the bottom away from the holes that hold the cover over the pedals. My right break rod was worn out, too. IH still has the rachet paw/rod for ONLY $185.00. I had a machine shop cut off the old rod and turn a new one to weld in its place. They also bored out the casting and put in a bronze oillite bushing. I figured anything from a junk yard would be worn out too. Good luck.
Post a Followup
: Re: Re: A's Brake Pedal Lube?
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
