Farmall Tractors Discussion Board
Adjusting generator output on Farmall B
Posted by Mark Selby on May 27, 1999 at 18:59:46 from (208.27.13.127):
Took the generator to the shop the other day...field was burned up and had to be replaced. The generator man said I could adjust the output by moving one brush either up or down. He showed me the screw to loosen, etc. Have any of you all ever done this? It's putting out only about 2 -- 3 amps even when the switch is on the high setting. Shouldn't it be a few amps more? Should the engine be running when I'm adjusting so that I can watch the meter, or should I move it a little while the engine is off, then fire it up and check the meter? Thanks.
Post a Followup
: Re: Adjusting generator output on Farmall B
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
