Well Brad - if it had been running good and the problem's junk in the carb, remove and disassemble the carb and give the parts a thorough cleaning. Reassemble with a new gasket kit - $25 or so - and you'll be good to go. (Keep in mind the SM carb is very simple and easy to rebuild...)
However BEFORE you get into the carb check your ignition timing! Could be the cam gear hub has broken and messed up the cam/spark timing. It's a common failure on the SM with live hydraulics. And it's consistent with the symptoms you describe. (Correct timing should be within a couple degrees of TDC.)
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
