Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Where to add oil
Posted by mj delaney on May 31, 1999 at 05:09:10 from (198.167.60.43):
In Reply to: Re: Re: Re: Re: Where to add oil posted by The Red. Also Levy on May 30, 1999 at 14:12:48:
When changing the oil filter which should be done every 100 hrs or so, take the time to make sure the canister is properly seated in the groove where the rubber gasket is positioned; this can be tricky and result in a persistant leak if you don't get it right. There is always a danger of overtightening too. On top of the canister there should also be a copper sealing ring where the bolt goes through. Obviously, if you change the filter, you should change the oil. I assume this tractor has been using detergent oil. If not, there can be concerns with sludge. I assume the engine is clean and sludge free inside?
Post a Followup
: Re: Re: Re: Re: Re: Re: Where to add oil
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
