Farmall Tractors Discussion Board
Re: 3 good tune-up tips for beginners, back to back (#1)
Posted by mj delaney on May 31, 1999 at 07:11:49 from (198.167.60.43):
In Reply to: 3 good tune-up tips for beginners, back to back (#1) posted by RKS on May 31, 1999 at 05:06:50:
This is all good advice.
I like to do things as simple as I can. To set the camlobe at tdc. I just push on the fanbelt and bring the engine up to tdc with the fan blade. I find tdc by shoving a small screw driver down the spark #1 plug hole. If you are too rough with the fan blade, this is not a recommended method. If you are gentle, it works not too bad.I've owned my H for twenty years now with no ill effects using this method. As far as timing is concerned, my H has always started as long as the points are set anywhere close. I don't have a dwell meter or timing light. If you have too much advance, the engine doesn't crank too well, not enough and it seems the motor is lazy. There's quite a variation in idle quality when you shift the timing. You just know when you've got it right especially if you have a good load for the tractor. Properly tuned, the "H" will lug right down to a heart beat although this is not recommended. The "H" is built to work and for a small gas tractor, they really are good performers.
I can pull a baler and wagon loaded with 200 bales just about any where in low gear. This will haul the rpm's down especially on a grade!
Post a Followup
: Re: Re: 3 good tune-up tips for beginners, back to back (#1)
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
