Farmall Tractors Discussion Board
Cub PTO Grinding!
Posted by Al Davis on June 01, 1999 at 06:51:16 from (12.27.104.2):
Dad just bought a semi-restored (engine only I believe) '49 Cub with an underbelly mower deck. While the motor/transmission run wonderfully, enganging the PTO using the small lever just to the rear/right of the gear shift results in a gear grind when you let the clutch out. I'm not a transmission man, per se, but fixing this is probably well within my ability if I have some clue towards what I should look for or adjust. Any help the group could provide would be greatly appreciated.
Post a Followup
: Re: Cub PTO Grinding!
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
