Farmall Tractors Discussion Board |
Re: Farmall Cup Hydraulics
Posted by Mey on June 01, 1999 at 18:18:20 from (204.97.23.172):
In Reply to: Farmall Cup Hydraulics posted by Dave on June 01, 1999 at 16:53:13:
Dave, I'de start by draining the old fluid out. It takes Hy-tran oil from Case/IH. When you refill the system, Leave the fill plug out, then with the engine running about half speed, move the lever back & forth about 12 times, that will bleed out the air. If that does not do it, you can rebuild the hydraulics your self. If you get to that point email me and I will give you the kit numbers to order from Case/IH and instructions. Mey (maple@top.monad.net)
Post a Followup
