Farmall Tractors Discussion Board
Re: Governor adjustment on Super A ???
Posted by Curt Cooke on June 02, 1999 at 05:39:09 from (207.75.224.250):
In Reply to: Governor adjustment on Super A ??? posted by bronco on June 01, 1999 at 20:09:25:
The most common problem in this regard is worn out linkage and related parts. First adjust the throttle linkage between the carb and governor shaft to spec. If the problem persists it's because of worn linkage or the anti-surge spring being adjusted too far in. Back the surge screw out enough to be sure that it's not holding your idle up. The screw is located on the bottom of the governor housing under an acorn nut. If the problem still persists you'll have to compensate for wear by shortening the rod between the carb and the governor, usually by the adjustable turnbuckle on the rod.
Post a Followup
: Re: Re: Governor adjustment on Super A ???
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
