I would focus less on the alternator and more on the 12v ignition conversion. Did you switch the coil leads so that hot is to plus and distributor is to minus terminal? (assuming you were positive ground before). Are you getting a healthy spark? This is the time of year where caps and rotors die because of condensation in my neck of the woods. Is your starter cranking well? When I installed my Hitachi, nothing was right until I rebuilt my starter because I had fried a brush connection trying to start it with a poor charge. Now it (my 1966 140)fires up like a champ since 2005 when I put it in.
Wiring is big post of Hitachi to Load side of ammeter (away from battery) and to outer smaller terminal on alternator. Inside (i.e. closer to center) small terminal goes through light/resistor/diode to key switch (coil side, not battery side). Same as BobM's #5 diagram, you just need to know that the outside little terminal on the Hitachi is equivalent to Delco #2 and inside to #1.I recommend a NAPA idiot light TGA 10 made by Echlin--looks right, works great, and just needs a 5/8" hole to live in.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
