Farmall Tractors Discussion Board |
Re: Super A clutch
Posted by Kent Morris on June 11, 1999 at 07:21:07 from (205.188.192.22):
In Reply to: Super A clutch posted by michael 'the legend' on June 10, 1999 at 20:44:57:
Micheal, The best fix is to split the tractor and do the job right. Even if you do manage to free the clutch without tearing it down you will have a problem. The transmission input shaft has very little drag on it and any friction at the clutch will make it difficult to shift. I have a Super A that had a stuck clutch and I was able to free it. However there is enough friction for the transmission shaft to turn and I have to throttle down to idle before shifting from neutural to prevent grinding the gears. I have other tractors with the same problem. Some of this can be cause by the Pilot Bearing. So, when you split your tractor to repair the clutch make sure you service the pilot bearing as well. Good Luck, Kent
Post a Followup
