Farmall Tractors Discussion Board
Re: Re: Re: farmal 300 clutch prob.
Posted by Ronnie on June 13, 1999 at 10:06:16 from (208.30.90.105):
In Reply to: Re: Re: farmal 300 clutch prob. posted by tlo on June 13, 1999 at 07:59:37:
To find out if it's the clutch put a load on the clutch by applying the brakes,(I use forth or fith gear) if clutch is slipping you should be able to bring the tractor to a stop without killing the engine. Then you will smell clutch, it might be the engine clutch or it could be the TA clutch if your on the high side, so you will want to work the TA on the high side and then on the low side. If the engine pulls down where you could kill it then it's the engine. I would check for dirt in sediment bowl first then the carb. for dirt and old fuel will make a tractor run bad. Might need to just adjust the carb. a little. Give this a try before you miss with the governor.
Post a Followup
: Re: Re: Re: Re: farmal 300 clutch prob.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
