Farmall Tractors Discussion Board
Re: hard shifting
Posted by Larry on June 13, 1999 at 12:50:04 from (206.228.213.115):
In Reply to: hard shifting posted by Todd in Redlands on June 13, 1999 at 11:17:55:
Frequently hard shifting problems are related to clutch adjustment. With your hand depress the clutch pedal to the point when you get major resistance. The travel is referred to as free travel. Too much free travel results in the clutch disc not being released properly by the pressure plate. This situation can cause the shifting problem you referenced. Adjust the clutch to the point that you have about 1/2 inch of free travel and see if this corrects the problem. Always maintain enough free travel to prevent the release bearing from rotating when the clutch is all the way released. If this does not fix your tractor you will probably have to change the clutch.
Post a Followup
: Re: Re: hard shifting
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
