Farmall Tractors Discussion Board
Re: 400 Diesel question for Ronnie
Posted by Ronnie on June 13, 1999 at 14:52:45 from (208.30.90.134):
In Reply to: 400 Diesel question for Ronnie posted by Todd on June 13, 1999 at 09:58:27:
Injection pump gettting fuel could just be the seal out in the scavenging pump. To start the tractor: 1- the throttle must be in off position (no fuel going to the injectors), 2- the compression lever must be in the gas position (on my 400 the lever is back for gas setting) watch the rod that comes off the compression lever, make sure it moves forward when lever is moved, you should hear it click and stay there. 3- pull the choke out. 4- start and adjust choke to keep it running (there is no throttle on the gas side) only the choke to help keep it running. 5- let engine warm up on the gas for a minute or two. 6- move compression lever back and open the throttle at the same time to get it switched to diesel. Now to shut it off, switch it back to gas, turn off the key to kill the spark and stop the engine. THEN PUT THE COMPRESSION LEVER IN THE DIESEL POSITION AFTER STOPPING THE ENGINE ON GAS SO THE STARTING VALVES COOL ON THE SEATS. The head has three valves per cylinder, the intake, the exhaust and the starting valves. The power steering won't be up to the 4020 but not bad. All 400's would have dealer installed power steering. Behlen is the best power steering, it was the factory choice on the 450 series.
Post a Followup
: Re: Re: 400 Diesel question for Ronnie
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
