Farmall Tractors Discussion Board
Re: Re: 12v to 6 v coversion !!
Posted by Larry on June 23, 1999 at 07:47:55 from (206.228.213.115):
In Reply to: Re: 12v to 6 v coversion !! posted by Phil Auten on June 23, 1999 at 06:29:27:
If you want to understand how the tractor is going to crank and run on 6 volts just turn off the lights. disconnect the gen/alt, install the 6 volt battery and heavy cables and fire it up. I run 12 coils on 6 volt cars leaving the resistor in place with no problem. If you are a purist and want the tractor to be original put a 6 gen on it provided you are satisfied with the above test. If you are more interested in dependability abort the above effort and stick with the 12 volts. If you have a problem with the 12 volts working correctly post you observations and we will assist
Post a Followup
: Re: Re: Re: 12v to 6 v coversion !!
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
