Farmall Tractors Discussion Board
Re: Re: Super A left wheel noise!!!
Posted by Rick K on July 02, 1999 at 05:23:19 from (205.181.231.254):
In Reply to: Re: Super A left wheel noise!!! posted by big fred on July 01, 1999 at 21:23:28:
There are 4 bearings on each side, as I recall. Two on the axle shaft and two on the differential shaft. Not 100% sure how you can tell which one it is without taking it apart. I replaced them all on mine last year. I suspect the left side takes a little more stress due to where the engine sits.
You might want to just order all 4 bearings and do them all at once, as long as you are going to have to take the whole thing apart anyway to figure out what is wrong. While you are at it, as I recall there is an axle seal and a differential shaft seal. If your brake band is at all questionable, this is a good time to do it as well, since it will fall off when you remove the left axle housing anyway.
The parts cost for all the above will probably be $150 ish.
Dissasembly is not that difficult, but the sucker is real heavy. I removed the axle shaft and gear first, which probably reduced the weight by 100 pounds or so. Two healthy people can remove the left axle housing at this point. Better would be to wrap a webbed strap around it and support it with a chainfall or come-along.
Rick
Post a Followup
: Re: Re: Re: Super A left wheel noise!!!
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
