Farmall Tractors Discussion Board
F-20 gear noise
Posted by Farmall Gray on July 02, 1999 at 06:46:02 from (152.163.201.79):
My F-20 makes a lot of gear noise when under power
but is fairly quiet when coasting. I suspect it has a bad bearing (or several) somewhere. I have to put wheel seals and brakes on it so I will have that apart soon, but I suspect the problem
may be one of the transmission bearings. Are there
any particular bearings that are prone to failure
on an F-20? It is a '39 on rubber with high speed
gears and it has been in use all its life so I
guess there's no shame for it.
Post a Followup
: Re: F-20 gear noise
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
