With that much Freeplay, the fork pulls back far enough to come off of the sides of the carrier. Just painful. Look to make sure the T/O is good, and the tips of the fingers are not wearing excessively. If such is found, a new clutch and PP may be in order. Kits are the least expensive way to go. As a disk wears, the freeplay becomes less and less. If the freeplay increases, the clutch linkage and or T?o are getting shorter from rear, or failure. The T/O fork can also be bent, and the Pin holding it to the shaft can be shearing off/loose, check that carefully. JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
