Farmall Tractors Discussion Board
Re: cub vs A
Posted by marvin johnson on July 13, 1999 at 13:42:42 from (134.134.248.23):
In Reply to: cub vs A posted by rick retter on July 13, 1999 at 11:42:35:
I was raised on a 50 acre farm with a cub and a A to run the farm. The cub had the hydralics so the mowing, plowing and blading was done by it. The a was used to pull the baler and the disk and the hay wagon. Basically beofre you can pick a tractor you need to pick the implements that you are going to use and then pick a tractor that will be capable to pull, poush or rotate those implements. The other issue is how long do you want to take to get the job done. You can get a lot done with a cub, it is just going to take longer. You can get even more done with a an A.
For the record I just purchased a Super A with a three point conversion and it is taking care of the needs on my 5 acres. Just need a sickle bar mower for it.
Good luck and let us know what you bought.
Post a Followup
: Re: Re: cub vs A
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
