Farmall Tractors Discussion Board
460 Farmall stuck in gear
Posted by LWilbur on July 13, 1999 at 20:57:24 from (209.152.64.224):
Tractor has a history of the end of the shift lever jumping out of the transmission rails, somehow moving 2 of the 3 rails out of neutral and simultaneously into gear when this occurs. Any time more than 1 of the rails is out of neutral, the tractor gearing is locked up and tractor won't move. Clutch appears OK and tractor will run as long as the clutch is in--dies as soon as clutch is put in, due to the locked up gears.
Have had luck in the past taking off the shift lever/housing and forcing (more force than I care to admit) the 2 rails back to the center (neutral). Once all three rails are in neutral, then I reinstalled the shift lever. Shift works for a while then problem reocurs. This time can't seem to get the 2 rails to return to neutral. Tractor has progressively been more difficult to shift unless all tension is off the drive. Especially a problem shifting when this tractor is used as a loader tractor, which it is now and then.
1) Any suggestions how to return the rails to neutral, short of total disassembly?
2) Suggestions on what to do to make this shift easier, so this doesn't reoccur. Or is this just old age and learn to live with it?
Post a Followup
: Re: 460 Farmall stuck in gear
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
